跳转到主内容
加入维修社区 - 创建账户
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
Mini Server 2010 - Fan doesn't work
I tried to upgrade one of the 2 HDDs to an SSD, and when I reassembled the Mini, it started overheating because the fan didn't come on.
Opened it up again, checked all connectors, same issue.
  • Put in a new fan, same issue.
  • Put in a new HDD sensor, same issue
  • Disconnected HDD sensors, same issue
  • Re-installed original HDD, same issue.
I've also zapped the NVRAM, and of course SMC resets after you've had it unplugged anyway.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Have you checked the temperature sensors? They can easily become damaged, resulting in a number of cooling issues. There are temperature sensors connected to the HDD and optical drive in those units.
完成的
No that vein how about using an app like TG Pro so you can 'see' whats really happening.
完成的
Thanks guys, yes I'm using TG Pro and even tried "Macs Fan Control", both report 0 RPM.
I've let it boot with the case open, and it's not turning on the fan for sure. Temperature sensors seem to work as the temperatures are reported in those apps...
Just not sure as to why the fan is not activated...
完成的
Then you've damaged the logic board some how.
完成的
Yeah, that's what I fear. Everything else works though, boots up and everything, it just doesn't run the fan and then overheats...
Any way to test anything?
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
I would do a detailed visual inspection to see if one or more components got damaged around the plug areas.
Here's two useful images to reference against:
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Simon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 243
