跳转到主内容
加入维修社区 - 创建账户
型号 NV370。机身高度 27 英寸,采用 Shark 的“永不损耗吸力”(never loses suction) 技术及旋转转向设计。
Shark won't stand up.
The silicone(?) collar that holds the floor nozzle into the tube that connects with the upright section of the body has broken. It is the part that keeps the two connected. Is there a cheap way to find or make a replacement?
The collar that is broken has two tabs to keep it in place. One has broken. The other tab doesn't quite do the whole job. It is a flexible translucent piece that looks like it could be made of stiff silicone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
If the vacuum won’t stand on its own, use this Shark Navigator Lift-Away Pro Won’t Stand on Its Own problem page for possible causes and solutions.
这个答案有帮助吗?
得分 1
添加一条评论
On my vacuum right next to the wheels at the base with a green top meets the black bottom can you try to stand the vacuum up the two pieces separate on both sides showing that the screws have ripped the plastic off the top part of the screws remain attached to the screw hole the whole top part needs to be replaced however there are security screws in place, the plastic shell which creates friction on the cam is broken so it no longer has resistance to hold the vacuum up, need a new top of the vacuum head
这个答案有帮助吗?
得分 0
添加一条评论
My shark QS100Q won’t stand up
这个答案有帮助吗?
得分 0
添加一条评论
I drilled right through the casing and put a couple of long bolts, washers and nuts to hold the whole assembly together. A bit fiddly but works a treat
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe Evans 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 64
总计 19,531
