跳转到主内容
The Lenovo IdeaPad 110-15IBR laptop was released in 2016.
My laptop doesn't connect to wifi
My laptop doesn't connect to wifi anymore. I don't know what specifically happened. It only shows me the possibility to connect by cable.
I would appreciate your help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
hi
what does you do to laptop
are you installing new windows
i mean whats happen before wifi stop
完成的
My laptop is the same I had to reboot n install windows now I can't connect please help
完成的
I replaced the keyboard on mine. The first how-to video said I needed to disconnect the battery to do it so I did. Now that everything is connected and put back together I had to do updates that were required as well as reset my connections but still only can connect using a ethernet cable. No way to change it back to WiFi. Help please.
完成的
Hi @pweibley68
What is the make and model number of the laptop?
What is the status of the WLAN adapter as shown in Device Manager?
完成的
添加一条评论
4个答案
最有帮助的答案
Hi @apalaci5 ,
Have you tried pressing F7 to disable airplane mode and then checking that the WiFi connect symbol appears in the lower right corner of the task bar?
If it still doesn't appear go to Device Manager and check the status of the WLAN (WiFi) adapter.
From the desktop, type Control Panel in the search box. Click on the Control panel desktop app link that is in the options box that appears.
When Control Panel opens, find and click on the Device Manager icon.
When Device Manager opens, scroll down to Network Adapters and click on the + symbol to expand the list.
Find an entry that mentions one of the following brands of WLAN adapters: Intel, Cybertan or LiteON. That is your WiFi adapter.
Is there a red cross or a yellow exclamation mark next to the entry in the Device Manager list?
If there is a red cross then right click on the entry and select enable from the options box that appears.
Check if it works OK now.
If there is a yellow exclamation mark, right click on the entry and select Update Drivers from the options box that appears, and follow the prompts to update the drivers.
You need to be connected to the internet via the Ethernet cable to do this. If you have no Ethernet connection available where you are what is the make and model number of the WLAN adapter as found in the Device Manager listing?
这个答案有帮助吗?
得分 4
1条评论:
Worked for me. Thank you
完成的
添加一条评论
This is what is shown
这个答案有帮助吗?
得分 0
2条评论:
I don't have the cord to connect internet so can't download drivers unless I can use phone
No I cannot see available networks it's like stuck on airplain mode
完成的
Hi,
If you have a USB cable you can download the drivers to your phone and then transfer them to the laptop via USB. Remember where you have saved them to in the laptop so that you find them when needed.
If you don't have a USB cable to connect the phone tothe laptop with you may have to ask someone else to download the drivers to a USB stick for you (or go to your local library and do it yourself) and then install them from the USB stick
完成的
添加一条评论
Hi @ Samantha Williams,
Did you try the suggestions as outlined in the Most helpful Answer above?
Can you “see” the available WiFi networks from the laptop?
If everything appears to be OK with the WLAN adapter as shown in Device Manager and if you have Win 10 installed, go to Settings > Network & Internet > Network Troubleshooter to see if it can resolve the problem for you.
Update:
Your WLAN adapter is not being listed in Device Manager
Try installing the WLAN drivers from here
这个答案有帮助吗?
得分 0
添加一条评论
When your laptop won’t connect itself to the wifi, there can be several reasons for this issue.
* wifi is weak.
  • driver or network issue.
  • Settings issue.
These are the two most common reasons for Lenovo laptop wifi not working issue. now here are the steps to fix this issue.
  1. put your computer nearby your router, and restart your laptop.
  2. change the wifi encryption and then try to connect again.
  3. Let’s update the wifi driver on your Lenovo laptop, and then try to access your computer again.
  4. Factory reset your laptop, and configure it again.
这个答案有帮助吗?
得分 0
2条评论:
It ipens the browser but cannot connect to page
完成的
How do I update my drivers
完成的
添加一条评论
添加你的答案
Ana 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 23
总计 20,142
