跳转到主内容
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
83 个问题 查看全部
My Ti 84 Plus ce won't turn on, even though it's fully charged
For the past couple of months my calculator has not turned on sometimes when I press the "on" key, even though it's fully charged. Also, it may not turn on one time, but an hour or two later, it would work like normal.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Does the RAM clear when it turns back on? If so, take off the battery cover and check that the battery is not loose.
这个答案有帮助吗?
得分 0
1条评论:
No, the ram does not clear, and I tried moving the battery around and that does not work.
完成的
添加一条评论
添加你的答案
Kingston Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,717
