跳转到主内容
Introduced in September 2004 and replaced with a version in 2010. The following model numbers apply: ZA11S, ZC71S, ZC11S, ZD11S, ZC21S, ZD21S, ZC31S.
18 个问题 查看全部
Why is my ABS and hand brake light on all the time? RESOLVED
Hi guys I would appreciate your help. I have a suzuki swift ZC31.the ABS and hand brake light is on all the time . How do I fix that?
Update (03/12/2018)
Apparently the ABS module had failed.And was swapped out with a junkyard replacement.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
My breaks ar light weight
完成的
添加一条评论
1个答案
最有帮助的答案
I had the same problem. I purchased a used ABS pump from a scrapyard and it solved the problem.
Use your smartphone to photograph the labels and numbers from the failed pump, to ensure that you get the right part.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joseph Fernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 32
总计 691
