This is really good stuff I have seen the issue with the different connectors and that its self is a big problem, send it back I found this seller on ebay and never had one problem with the white screen, black screen again, I own my own repair shop and been doing this for quit some time now and had this problem many times, run the battery out recharge, always on the connector that is on the underside use a bit of the 2mm double side tape after it is seated, when you replace the board back in it comes loose, that is why when you first open it up it has the copper heat sink tape on it not only for the heat but to keep it sucurely in place, I also use the amber heat shield tape to hold the top cable down securely because when u move it just a bit putting it back in it can wiggle loose, thus the white screen. The ebay seller I use is
Hudson_River_Goods (10360) $24.45 in the 3 years of dealing with them never a problem with the white screen, make sure its off before you start, be care with everything, and dont heat to much before or after, heat will also cause these cables to be unstable at the screen side do to they are not soldered to they are heat pasted soldered thus heat will loosen them. The guy above with the pic showing the difference in the connector is right, one is for the begining ipod in the that gen and the other is for the later in that gen, if you go cheap you get white screen use the seller I told you about and you will be just fine, good Luck.
Thank you and Good Luck
9条评论
I just tried to fix an ipod touch 4g with cracked glass. After a careful teardown and re-assemble I encoutered the same issue. I even tried connecting the old screen with the cracked glass but found the same white screen haunting me. I am going to try recboot but I am now wondering what to recommend to the customer I have. Any progress Travis?
由 Bill Artz 完成的
Hey bill. I did eventually get mine to work but I ended up getting another new lcd from the same guy who sold me the first one. When I plugged in the second one it immediately showed up. If your having the same issue then out could possibly be a faulty lcd. I was also told the lcd and digitizer had to be fuzed together but they were incorrect cause mine works just fine in two separate pieces. I hope this helps! -travis
由 Travis Mo 完成的
my iPhone 4s screen is comepletely white now and my dad bought a digitizer and lcd thing to fix it do you think this will solve the problem?
由 craycareer 完成的
Hey
I got the same problem.
http://desmond.imageshack.us/Himg513/sca...
But if i put the old screen in, all works fine. But with the new I got this. I already reset the ipod etc but nothing seems to help.
What do I need to do?
Kind regards
由 Willem 完成的
Recently, I bought iPod Touch 4 LCD Assembly from China after replacing it, my screen went to white only. Eventually, I realized that Digitizer connector is different from original one. The original one has wider plastic block in the middle of connector than faulty one from China. Do you think that the different connector makes white screen problem?
由 Simon Pan 完成的
显示更多的4条评论
