跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
My touch bar got cracked and is no longer functional
My touch bar got cracked and the display is no longer functional, can someone give me an estimate how much would it cost to get the touch bar display replaced form the  store?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
have you got a image, how did it become cracked ?
完成的
添加一条评论
2个答案
最有帮助的答案
Replacing the touch bar requires a full topcase replacement, and Apple will replace the battery with it. Unfortunately it's pretty expensive. A full topcase assembly comes in (prices from the netherlands) at roughly 500 euros (€ 499,20 to be exact, excluding taxes, which brings it up to 600 euros in the netherlands). Add labour to that to get a full estimate, and you'll end up in the 700 euro range.
这个答案有帮助吗?
得分 1
添加一条评论
I would imagine it would be pretty expensive it would most likely be a top case replacement, and not only that I don't if apple will also change the logic board as they are married to the touch i.D sensor which is part of the touch bar.
这个答案有帮助吗?
得分 0
2条评论:
Sorry, this is not true. The touch id sensor is a seperate part. It is possible to only replace the touchbar, but this is not for the faint of heart. A new touchbar comes at prices around $50, but to replace it is a nightmare.
完成的
Sorry, yes i know that, but I was explaining the outcome if he visited an apple store because that is what he asked for.
完成的
添加一条评论
添加你的答案
Saad Ahmad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 2,192
