跳转到主内容
The Xterra was introduced in North America in the 2000 model year (1999 calendar year) and marketed using the tagline Everything you need, nothing you don't.
13 个问题 查看全部
Front bumper almost touching tires
How to remove front bumper
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
@magrady try this
FRONT BUMPER ASSEMBLY
NGBT0004S01
1. Remove clips securing front grille and remove the front grille. B''italic text''
2. Remove the side marker lamps.
3. Remove bolts securing left and right bumper stays. C''italic text''
4. Remove the lower grille opening trim. A
5. Remove bolts securing left and right bumper side brackets. D
6. Remove the front fascia.
7. Remove bolts securing left and right bumper from bumper brackets. E''italic text''
8. Remove bumper assembly.
这个答案有帮助吗?
得分 4
4条评论:
Mike, you never seem to cease to amaze me with what you can find ;-)
完成的
@mayer yes Sir, got lots of stuff laying around and keep every manual nicely sorted and ready to go. Man, half the time I'd be lost with my repairs if it wouldn't be for those :-))
完成的
do you have any idea on how to put it back on? the clips for the grille are very hard to re install, but if I can't figure it out, I probably will just zip tie it.
完成的
I haven't worked on this particular vehicle before, but from what the pics I could find show they're basic clips. They have to be strong as they're all that hold the grill on. Put it in place, get them lined up, and using the palm of your hand, give it a smack to pop them it. Try to make sure you're smacking where there is a clip, not between 2 clips, to prevent cracking of the plastic. It might take more than one smack but it will go in. Chevy truck grills have some serious clips too, and this is what I use for them. Works every time. Make sure they stay aligned as you go, or you're smacking for nothing.
完成的
添加一条评论
添加你的答案
Tracy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 19
总计 2,802
