跳转到主内容
于2016年3月上市。型号 SM-G930V。
425 个问题 查看全部
S7 shows charged percentage even with BATTERY REMOVED
Samsung Galaxy S7 owner here. At some point, the original battery got bloated, so I decided to replace it. After the replacement, with the new battery, the phone wouldn't charge and would turn off after as soon as I removed the charging cable. Charging percentage would show a random constant number (the favourite was between 57 and 60 but could vary).
So I took the new battery off and plugged the charger in without a battery attached. And guess what? The phone shows a random charged percentage (this time fav range is 35-40%).
Tried hard resetting, pressing the power button to drain the capacitors, clearing the cache, nothing helped so far. I am clueless where that number could come from and I am guessing that when the battery is hooked on, the phone doesn't even recognise it.
Any help appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I had the same exact situation with my S5. Replaced the bloated battery and the same exact issue. From everything I have gathered it's a fairly common issue with Samsungs. The main PMIC or one of its nearby passive components on the motherboard that's hooked directly into the battery terminals has most likely failed. Changing this main PMIC will most likely fix the issue for you.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
galaxy_mess7 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 115
