跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
Speaker distortion after Logicboard exchange.
I changed the Logicboard of the iMac. Since I did this the speakers are not working properly. If I plug in both speaker cable then the right speaker (looking as user) ist making distored sounds already on the startup chime. If I plug out the other speaker, then the right speaker sounds good! If I plug in just the left speaker (the one with the subwoofer), then no sound at all.
What could cause this problem? I changed form a i5 board to a i3 board and replaced all my i5 items (GPU, CPU, heaters). But I don't suspect this to be the issue.
I checked the Ohm on both speakers. Between 1-2 it is 5 Ohm and between 3-4 it is 10 Ohm. This is true for both speakers. So, no short circuit apparently.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The problem was that I accidentally pinched a cable to the left speaker with a screw that fixes the logicboard. I made sure there is no contact and then it worked well again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 45
