跳转到主内容
The HTC U Ultra is also known as the HTC Ocean Note and was released in February 2017. HTC U Ultra includes models U Ultra, U-1u, and 2PZF1 and was released in black, pink, white, and blue body colors.
7 个问题 查看全部
Why is my phone charging so slowly
Since past few days my htc ultra u is not charging like the way it did before
Its taking almost 12 to 13 hours to do full charge and after chargin when i plug off my charger the battery drains very fast
I also have changed the battery but the issue remains the same.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hello Khawaja Ahmed, I would recommend replacing the charge you are using, and make sure it its the proper wattage and voltage, it is possible as well that it is a weaker outlet.
这个答案有帮助吗?
得分 0
2条评论:
I have this same problem with my U Ultra. It stopped fast charging and will only slow charge now. Using the same cable I've been using all the time. Cable still fast charges my HTC 10 fine. Cleaned the USB port, restarted phone, turned off phone for a few hours, and tried 3 different cables that all work fine with my 10 so Im fairly confident it's something wrong with the phone and not the power source.
完成的
Hello. How did u solve this problem? I have too
完成的
添加一条评论
there is a firmware update. (offered with US carriers(?), go to settings and update in there somewhere)
if search the forums, no real way to fix the battery thing
I have the phone in a charging loop (Powers on the screen then shuts off)
(I suggest get a new phone) nokia or samsung. I got Samsung A50 on BF special at Best Buy
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Khawaja Ahmed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,814
