跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
The cable won't connect
I did a screen replacement on my iPhone 6+, and the cable in the photo: https://imgur.com/tPbQQzr
Won't connect to the phone. What can i do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
That's the front camera sensor yeah? Is it all original cables? or have you replaced any
完成的
Original one, the camera worked before i did the repair
完成的
添加一条评论
1个答案
Hi Tomer,
If the connection on your motherboard isn't mashed or damaged then you should have no problem plugging this cable in.
You could be attempting to plug the cable into the wrong socket on the mainboard, a mistake I see trainee's making when doing iphone 6 repairs and not putting the cables in the right spot.
The cables should not sit behind each other, and will all neatly line up to where they're supposed to plug in.
Try tucking the speaker flex cable behind the screen cables, or visa versa.
Good luck!
~S
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tomer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 95
