跳转到主内容
Repair guides and support for motorcycles manufactured by Honda.
74 个问题 查看全部
1980 cb650custom choke engine mount melted
Is there a metal piece that can be replace instead of the plastic part? where the choke cable mounts to the engine block there is a plastic connector. Which has melted away. Now the chock won't engage. I order to replace I have to take apart the a lot of parts and don't want to do it again down the road. I'm up for alternative methods to fixing this. Currently the rest of the bike is still stock for a 1980 Honda cb650 custome, made for Italy. I'm in Okinawa Japan and hopefully I can find a shop to help me with this old beast.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Catherine, from what I can see. The choke cable knob is mounted up near the instruments on the handlebars, or at least it should be. Then it runs from there down under the tank and connects to the choke actuator. The only thing I can think of that has melted would be the plastic outer cable, and this would cause a bit of mischief.
My suggestion would be to remove the tank and trace the cable and see where it runs and how it is attached. Then get yourself another cable, plenty on ebay. And mount it up on the handle bars near the instruments where all the others are and attach it to the frame via a stainless steel zip tie. They usually only run through a metal 'push tag'. Get some shrink tubing put that over the zip tie shrink it, to protect the cable from chaffing then attach. That should cure your problem.
Take a look at the video below, it will show you what I mean, also mind the language :)
Different bike same story
这个答案有帮助吗?
得分 0
2条评论:
https://goo.gl/images/Cf6CVj in this image, it's the black piece that's melted. This is where the cable mounts to the engine.
完成的
Catherine, do you have a picture from your own bike. Because when I click your link, it shows a page with a whole load of bikes.
完成的
添加一条评论
添加你的答案
Catherine Goeddey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 107
