Unable to login with my normal username & password after crash
About a week ago, I got a "service battery" notification, after I let the battery discharge completely.
The other night, the system abruptly shut down while running on battery power, at 40% remaining charge.
I plugged the power adapter in, waited for the battery to recharge, and attempted to re-boot: it took over an hour.
When I did get the login screen to display, I noticed that my user picture was missing, and I am unable to login using my username/password, as if my user profile has been deleted. Also, the system beachballs at the login screen, while attempting to enter data, or while using the trackpad. I see no option for logging in as a new user.
I have reset the PRAM, and attempted to restart in Safe Mode, but still experience the same problem. I ran Disk First Aid and everything checks out fine...I replaced the HD about a month ago, and it should be ok.
I am now thinking about re-installing the OS, however, I ordered a new battery that will arrive day after tomorrow: Should I wait, and install the new battery BEFORE attempting to reinstall the system software? Or, should I just try to reinstall now?
Could the battery itself be the root of these problems?
Any advice is much appreciated...thanks in advance!
Do you have another PC that you could use for something?
由 Aiden 完成的
Yes...I'm using a linux-based Eeepc to write this, now.
My 13" MacBook Pro is a late 2011 A1278, running 10.13.
由 Joe Bloggs 完成的
Would you have any way of connecting the hard drive from your "crashed" pc to your Linux box, like a hard drive dock?
由 zjr60963 完成的
OK. linux has built in HFS+ read capabilities, so we can skip installing paragon HFS+. Connect the Mac hdd to the Linux PC and boot into linux off your linux drive. NOT THE MAC DRIVE.
由 Aiden 完成的
Oh its a laptop.
Do you have a SATA to USB adapter?
由 Aiden 完成的
显示更多的8条评论
