跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Second generation of the Fairphone, made by the social enterprise with the same name. Released in December 2015. Model number: FP2-XCVR
63 个问题 查看全部
Can't call or send texts, Radio stuck on off
Hello
I've had a problem where I can't use my sim cards.
At first I thought my phone was stuck on airplane mode but that was not the case.
It seems to be a network issue as both my sim cards are affected. And my phone simply states no network.
I can't seem to switch from 4G to 3G or 2G for one. I click the option but it remains fixed on 4G.
When I make phone calls there's a notice that says Radio Off and so the call does not go through. Hence I can't even call fairphone
The one number I could call led to a prompt.
I called the number to try and have the radio switched on but like the 4G option the radio remained fixed on off.
Also my WiFi works fine it's only the mobile network.
Has anyone had a similar issue? Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
评论:
Having the same problem radio off and airplane mode radio off I know it's not in airplane mode I know how to turn the radio off I have hard reset phone still no luck I don't know this one. I am able to use Wi-Fi internet.
完成的
Same problem here How to recover that plz help
完成的
Yes please help us same issue with me I'm using redmi note 4
完成的
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
4个回答
最有帮助的答案
Hi @dkwene ,
Try starting the phone in safe mode to see if perhaps a downloaded app is causing the problem.
Take heed of the "Please Note" near the top of the page.
Update (03/01/2018)
Hi @dkwene ,
Try inserting a different known working SIM card which uses the same network provider as your SIM cards and see if it works OK. Check if your card(s) work in a different known working same network phone. Basically swap SIM cards between two phones.
If it still doesn't work try a factory reset and then check if it works OK.
Be aware that a factory reset will erase all your data and downloaded apps, it will restore the phone to its' factory default condition. It will be like when you first bought it.
Before you perform a factory reset, backup the phone first using the phone's backup feature. That way if the reset solves the problem you can restore the phone, with all your data etc, from the backup that you made, using the phone's restore feature.
If it still fails after the factory reset, then the phone is faulty.
As it is new, consult the manufacturer's warranty statement, usually found with the documentation that came with the phone or in the User Guide as to what you have to do to make a claim for a manufacturer's warranty repair, replacement or refund
这个答案有帮助吗?
得分 1
评论:
Hi jayeff I started it on safe mode and it still has the same issue. Might you know a way to turn on the radio?
完成的
添加一条评论
Pull Sims out and clean them off with a Qtip
Then blow any dust out of where the sims go
Try that first
I once had the same problem turned out to be lint in the Sim Card Tray
这个答案有帮助吗?
得分 0
评论:
Still no luck, I've tried switching round the sims cards and also just having one some card in. It's a new phone I've had it for about a week. I've attached an image showing the service status which is what I'm having a problem with the most. Still unsure how to switch on the radio
完成的
添加一条评论
Did you turn on your radio while you were on call before this problem happened?
I tried turning on the radio while on call and it gave me this message, “Please do not turn on fm radio during a phone call".
I guess it causes some problems that's why instead of the usual message of “Cannot start radio” or “Can't start the service” it displayed this message “do not turn on “.
这个答案有帮助吗?
得分 0
添加一条评论
I just experienced it now…..but then I just restarted my phone..and the network came back
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dianne K 将永远感激不已
浏览统计数据:
过去的24小时: 9
过去的7天: 102
过去的30天: 473
总计 4,654
