跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
Boot camp issue. “Windows could not prepare the computer to boot...”
I’m trying to install a partition of windows on my 2011 MacBook Pro. At first, I used boot camp but then windows refused to install on the formatted partition and I got the “GPT” error. So, I instead, rather than using boot camp, made the NTFS partition manually. Now, I get the following error after the “installing updates” part is checked in the installation menu: “Windows could not prepare the computer to boot into the next phase of installation. To install Windows, restart the installation.”
I’ve tried resetting the PRAM and SMC and had no luck. This Mac has the famous GPU problem so I have currently programmed it to only run on integrated graphics. Could this be the issue? I don’t know though I get a feeling that the GPU is not the problem because this error appears to be fairly common despite no definite solution existing online. Anyone have advice on what to do? I’m installing windows with a usb drive with an iso installed into it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sadly I think you nailed it here ;-{
The Windows installer is trying to use the dedicated GPU but as you disabled it Windows is stuck in limbo.
这个答案有帮助吗?
得分 1
9条评论:
Interesting. Is there a way around this? Since I forced macOS to use integrated graphics I assume I can do the same with windows, right?
完成的
You'll need to revert back so the GPU is enabled to get Windows to install.
完成的
Alright. So I reset the PRAM which also reset my GPU settings, so the computer now can use the failed amd GPU. Now upon installation, I get this message “Windows could not update the computer’s boot configuration. Installation can not proceed.”
完成的
What is your Mac OS version and your MS Windows version?
完成的
I am installing windows 8.1 Pro on my 2011 Mac which is running high Sierra.
完成的
显示更多的4条评论
添加一条评论
you must use an USB key boot with the iso of windows 10 create on a WINDOWS machine +++
when the usb install key is created under mac os (High Sierra), it ‘ll not work !!!
see the last answer here : https://discussions.apple.com/thread/855...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cameron Torres 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 4,702
