跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314 个问题 查看全部
How can I fix a DS Lite that does not maintain its top case position?
I would like to repair my old DS Lite that felt on the ground many years ago. It still works but now it has a hole which reveals its hinge. The problem is that when I open the DS Lite to play its top case won't stay in position, infact I can't hear any "crack" that usually it does when the top part locks to stay in that specific position.
Which parts have I to buy to fix it?
Here are some images:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @dadeaka ,
It looks like the upper case will have to be replaced.
Here is a link to the ifixit Nintendo DS Lite Upper Case Replacement guide, which should be of some help.
Here is a link to a supplier of parts for the device. (scroll to the bottom to find upper case parts). It is not a recommendation to use them. It is shown to give an idea of the cost of the part.
这个答案有帮助吗?
得分 1
3条评论:
Good luck finding a screwdriver that small! Lol
完成的
Hi,
I might have the last laugh
Tools required:
Phillips #00 Screwdriver
Tri-point Y1 Screwdriver
完成的
Can I just ask, when the OP says the top case doesn't stay in position, do you mean it is really floppy? My DS has no resistance at all to keep the screen in place. I just wondered if replacing the upper case will resolve this issue too? Thanks
完成的
添加一条评论
Nintendo will fix it for free. The thread is a bit old, but you should call Nintendo support and ask.
https://www.engadget.com/2006/07/21/nint...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dade Aka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 2,556
