跳转到主内容
October 2016 marks the date that this Acer Chromebook hit the market with its 360 degree, fan-less design.
8 个问题 查看全部
SSD upgrade or change?
Can i upgrade or change SSD ? M.2 format ? mSATA ?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
This system uses a soldered on flash drive on the logic board and is not replaceable.
这个答案有帮助吗?
得分 4
添加一条评论
One can also use a pre-flashed SD card, or maybe even usb-to-nvme adapters, and load the operating system that way. Please review this documentation:
https://github.com/hexdump0815/linux-mai...
https://archlinuxarm.org/platforms/armv8...
I'm currently using this Chromebook with Debian and ChromeOS dualbooted. Note, the SD card should be a high-endurance one like A2, which is made for applications and often utilization.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bernard S. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 810
