跳转到主内容
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
Why wont my ps4 show up on my tv?
My ps4 hasn't been working for two days. I have tried 3 different HDMI cables, two tv's and it still wont work. Safe mode isn't coming up but my tv does recognize its connected to a playstation. Their is also sound coming through my headphones when connected to my controller. The light shows itstarted properly (blue light then white light). what should I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 68
63条评论
When you say safe mode isn't coming up, have you attached your controller to the PS4 via a usb cable? As that is the only way to get safe mode to start.
完成的
I had the exact same problem. I unplugged the ps4 for 24 hours and connected the hdmi into another port before turning it on. It worked! I then powered it off and then connected the cable back into the original port and it still worked. Not sure if it had something to do with the amount of time I had it unplugged or if it was switching ports.
完成的
My question is, my ps4 does this but only for one tv that I own, I’ve hooked up other things to the tv via the same HDMI cable and port and they work perfectly, I’ve also hooked up my ps4 to another tv in my room with no problems via HDMI so I know it’s not my ps4 either
完成的
Mine suddenly started doing this also !!
完成的
I have the same problem, but you have solved the problem.
完成的
显示更多的58条评论
添加一条评论
11个答案
已选择的解决方案
Sounds like an HDMI port problem. This is very common with Ps4's, especially the older ones. Sometimes you can shine a flashlight into the port and see the bent pins. If the port looks good it can also be the encoder chip on the motherboard.
这个答案有帮助吗?
得分 24
29条评论:
if it's the encoder chip how do we fix it?
完成的
To fix them you have to heat them until the solder melts, then place the new one in its place
完成的
How do you fix the bent pins ?
完成的
thank you for this. It helped me so much
完成的
fellas, this is happening to me right now, and i tried different hdmi and nothing works , im really not good at thoose things and dont want to kill my ps4 buy shoving a fork inside his HDMI port. what can i do?
完成的
显示更多的24条评论
添加一条评论
最有帮助的答案
Connect the hdmi cable turn on the tv but not the ps4, Now Pres and hold power button for at least 7 secounds until system beeps twice.
This worked for me so i hope it hepls you too
这个答案有帮助吗?
得分 26
15条评论:
it did not work for me.How strange?
完成的
What does this do? I’ve had to do this every time now to get it to work.
完成的
Does not help AT ALL
完成的
It doesn't work because it beeps twice and then turns off
完成的
Ok so, I had the exact same problem, when you unplug your PS4 HDMI and turn and hold the PS4 power button for the second beep, it resets the PS4s resolution to 480p... chances are at one point or another you accidentally set the resolution to a high one than your tv can support... how I did that I have no idea and you problem don’t either. Your PS4 will then give you a menu to select an option from(one of them being adjust screen resolution). Hit that option and it will then prompt you to auto or manually set it... I just did it automatically and presto, it was set back to 1080p for the better quality. I instantly understood what was going on, if this doesn’t work for you, then sorry to tell you dude, but you’re gunna have to take it to Sony. Thanks for the help!!
完成的
显示更多的10条评论
添加一条评论
Unplug the TV and wait 5 seconds..unplug the back of the TV not the outlet.. your welcome.
这个答案有帮助吗?
得分 15
19条评论:
This actually worked for me.
完成的
This worked for me too!
完成的
That worked for me thanks 😊
完成的
Omg really bro!!! I tried everything and all I had to do was unplug my tv!!! 🤬🤦‍♂️🤣. Man ty!!
完成的
Thanks my guy!
完成的
显示更多的14条评论
添加一条评论
Experienced this issue multiple times and these following steps seem to remedy the situation every single time.
  • Make sure to have both your tv and PS4 (PRO) powered off.
  • Make sure to have the HDMI-cable not connected to your PS4
  • Power-on your tv and set it to the corresponding HDMI-channel
  • Press and hold your PS4 (PRO) power button and wait for the second beep to occur (this will enable safe mode)
  • After you hear the second beep, connect your HDMI cable to your console
  • Safe Mode will then come online, make sure to check for new updates (i found out that this issue tends to come up everytime Sony pushes a new software update).
  • This update should remedy the situation, the console will most likely boot up a few times afterwards. Don’t cut the power on this boot sequence.
  • Afterwards the problem should be resolved. If not, go back into safe mode and check your resolution. Put this on 720p just to be sure -> you can always change it back to your preferred resolution when the console is fixed via Options -> Sound & Screen.
Hope this helps someone out there. Cheers!
这个答案有帮助吗?
得分 5
8条评论:
I dont have ps4 pro i have the regular one
完成的
I only have the regular ps4
完成的
I've been using an analogue converter for an old tv, and the HDMI would work on others.
Now it only works through the converter. And I can't get the safe mode to trigger.
This is rediculous
完成的
Safe mode isn’t coming up on mine either so then what?
完成的
This worked for me! Thank you so much
完成的
显示更多的3条评论
添加一条评论
None of these have helped fix my issue. i’m going to have it tested at Game Stopthis morning. And if they can’t find the problem, then I am just going to buy a new one. I have tried everything on this page. And nothing works. My ps4 is not a Pro. It’s the Uncharted 4 edition game system. I’m guessing it’s because I’ve had mine for about 5 years and it is just worn out. We went to my sister in law’s and I hooked it up to her TV. We lost power at our house bcause of the tornados here in West Kentucky. It worked fine at her house. Then when we got back home, it won’t connect to the TV. I tried it on my other TV and it won’t work on it either. Lesson learned. I am not going to take my ps4 with me whenever we have to go somewhere else to stay. Lol
这个答案有帮助吗?
得分 1
1条评论:
Mines is old too😭I went to go plug in my ps4 camera and I picked up my ps4 to plug it in and it just disconnected from the tv
完成的
添加一条评论
I've had my ps4 for 2 or 3 years and suddenly it stopped working. It switches on but the TV says 'no signal' and my controllers blink white. I don't even know if it's a pro or not but considering none of these options work, it might not be. I can't repair it at shop because HK is having a lock down soon so electronic stores are closing down temporarily. Not to mention I need the money for it. Which I wager it won't be cheap. So is there really no way to solve it?
I doubt I'll get a quick answer since this page hasn't been updated with responses in a long while so I'll probably copy and paste this on reddit somewhere. Still, I want to find answers as fast as possible.
这个答案有帮助吗?
得分 1
3条评论:
Hi, during the last few weeks I tried all the ways found on the web but without success. Finally today I solved the problem using a hdmi switcher with the hdcp bypass (an adaptor that allows you to connect a device to two screens)
完成的
Hi Giack, do you have a link to the specific switcher you used?
完成的
@zurich46825 Yes, i just found it. I bought it on Amazon.
https://www.amazon.it/gp/aw/d/B00LCUJX9G...
完成的
添加一条评论
Right so basically everyone still reading this is sad get it repaired for 100 pound that’s nothing
这个答案有帮助吗?
得分 0
1条评论:
For a ps4 that's worth 199 whats the point of spending 100 to get it fixed when at that point u can buy a new ps4. That's why I haven't brought mine in the shop yet. I'm trying to find a cheaper option to solve the problem than paying someone that much to fix it when it's just worth getting a new ps4 then.
完成的
添加一条评论
worked for me as well thanks bud 👍
这个答案有帮助吗?
得分 0
添加一条评论
Worked for me thanks
这个答案有帮助吗?
得分 0
添加一条评论
Ok this has worked for me but it actually took longer than expected! I did the safe reset ( turn on the PS4 and keep holding the button for approx 10 seconds until you hear a second beep, then connect DualShock with USB ) and it didn’t work so I gave up and left it for like 5 min and then suddenly it connected to the TV! So you might want to give that a go
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
I still haven’t gotten mine to work. It fell it it’s topside and since then hasn’t given a display. I have booted it in safe mode and hard reset but it still hasn’t given a display. I know the HDMI cable works because I use it on my Xbox and I’m using the correct input. Please help me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ali Naqvi 将永远感激不已
浏览统计数据:
过去 24 小时: 131
过去 7 天: 882
过去 30 天: 3,948
总计 659,364
