跳转到主内容
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106 个问题 查看全部
Why my iPad doesn't go past Apple logo?
I have a A1430 WIFI + CELLULAR iPad which was running completely fine. However, it start discharging completely when the battery came down to 30% . Then , while plugging in to charge, first the red battery comes on followed by the Apple logo & keep going on loop. Doesn't charge or go beyond the Apple logo. Really frustrated & kindly requesting for suggestions. Pleasure
https://youtu.be/xx9VM6GMcnM
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Your problem appears to be a dead battery. It doesn't take a charge and it's not charged enough to boot the iPad. Considering the age of the device, this is completely normal. You can change it yourself, just check out this repair guide to see if your comfortable with all the steps.
这个答案有帮助吗?
得分 2
添加一条评论
Probably a dead battery, you should get it replaced.
I'm not sure if it could be a logic board issue because something similar is happening to my iPhone 5s.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robin Kalam 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 4
总计 78
