跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
216 个问题 查看全部
Looking for power pads for 13" MacBook Pro A1708 Function Key model
Older versions of the MacBook Pro have options to bypass the power button.
Does anyone know where the power pads are on the 2016 MacBook Pro 13" A1708?
The keyboard had liquid damage but the battery and logicboard are still receiving power.
I want to test the board/screen but I can't turn it on because the keyboard is damaged.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
最有帮助的答案
Try to see if the system will spontaneously boot up after you've disconnected the battery and just plugged in the USB-C power adapter?
这个答案有帮助吗?
得分 1
1条评论:
Tried this and it did not work.
I am not sure if the 2016 is setup like the older models. Older models would turn on when the Magsafe was connected. Does anyone know if the 2016 a1708 works this way?
Will the USB C turn the computer on without any buttons being pressed?
Thanks!
完成的
添加一条评论
添加你的答案
mrkiki 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,261
