iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
672 个问题 查看全部
Charged $200 to repair and it worked two days
A local repair shop replaced the screen, charging port, and put a new battery in my phone. I was told there was some water damage inside but that those components were replaced.
I used it for two days although it seemed just a little sluggish. It still preformed any thing i needed it to. I had it in a thick Life proof case with built in charging backup. I charged it twice. The third time i charged i, when i checked it later it would not come back on. I tried the hard restart no luck. The case charged but the phone is dead.
The girl at the repair shop checked it out and, said she tried replacing everything again and, it still would not come back on. Claims it may have burnt up the motherboard.
I will get the phone back today and, put it on itunes to see if i can still see inside it.
I'm out $200. for nothing. All she will do is give me $20. off if i need a future repair.
Any suggestions?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
3个回答
已选择的解决方案
Water damaged phones are always a risky repair. They should always be properly decontaminated first. In my shop, if the phone needs a lot of new modular components (screen, battery, cameras etc.) following water damage, I generally don't recommend it to customers as the cost quickly supersedes the value of the device. The types of water damaged phones that have a better chance of long term success are those in which the damage is fairly localized on the logic board, for example the backlight or LCD circuit or the classic C5202 on the iPhone 6. Once you get into large scale corrosion, the device is more suited to a data recovery focus.
That said, every device and customer is unique. It sounds like you either weren't properly explained the risks or you didn't fully understand them (or maybe the shop was in over their heads).
这个答案有帮助吗?
按维修分数 3
添加一条评论
Out of warranty repairs at Apple are about $350. Now that everything is replaced, take it apple and they will swap it for a refurbished for $350, which is cheaper than buying a new iPhone.
这个答案有帮助吗?
按维修分数 2
添加一条评论
If it had water damage, I am shocked she even touched it. iPhones have built in water exposure indicators, and if they show water exposure, many shops (including Apple) won't touch them. As far as what you should do, maybe look at another iPhone. If you used iCloud backup or backed up to a PC/MAC using iTunes, then it is a pretty easy transition.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Jeff Chandler 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 42
