跳转到主内容
加入维修社区 - 创建账户
Game Boy(Game Boy 掌上游戏机)于 1989 年 4 月 21 日在日本发售,随后在 1989 年 7 月 31 日登陆北美地区,最后于 1990 年 9 月 28 日在欧洲上市。它的特点是拥有一个较大的灰色外壳,型号为 DMG-01。
Cleaned battery corrosion, but A and B buttons don't work
Hi! I came upon my brother's old original Gameboy yesterday. It had battery corrosion from years ago; I don't know much at all about electronics but have fixed a few toys with battery corrosion before. Gameboy wouldn't turn on; I took it apart and cleaned all the corrosion I could, first a little with baking soda/water and then with vinegar....Turns on now and everything works, EXCEPT for the A and B buttons, obviously making gameplay impossible...Links to pics below: is there anything I can do to get it working/what part is keeping it from working? I realize it's not completely clean but don't want to spend more time on if I've broken something beyond repair (some of the green...plastic? started "melting" off on the back side....was vinegar not supposed to touch that....?) If it can't be fixed, I guess we'll at least have a very cool Super Mario World 1-1 music player, haha. Thanks!
[IMG]http://i67.tinypic.com/35mozmg.jpg[/IMG] [IMG]http://i67.tinypic.com/1054jsw.jpg[/IMG] [IMG]http://i65.tinypic.com/2ldj1w2.jpg[/IMG] [IMG]http://i66.tinypic.com/ay0npe.jpg[/IMG] [IMG]http://i68.tinypic.com/kcxcah.jpg[/IMG]
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Hi!
Looks like you used the wrong type of alcohol, the vinegar seems to have corroded the electrical traces inside the mother board. You should have used Isopropyl Alcohol.
Now, about the repair: I've seen people fixing this kind of problem by basically bridging the corroded area with a cable: What you have to do is to is to scrub the protective green layer off the board (before the corroded area) on the side where you can see the traces (pics 2 to 4) until you get to the conductive trace itself, solder a wire there and where the corroded are ends.
This is not 100% guaranteed fix, but if you feel confident it could save yourself the hustle of buying a new board.
这个答案有帮助吗?
得分 2
2条评论:
Hi @alexniculescu ,
"Rubbing" alcohol will do if you cannot get anything better but you should really use IPA 90%+ (Isopropyl Alcohol - available at most pharmacies) to clean off corrosion and to disperse liquids when cleaning electronics.
Rubbing alcohol is usually <70% IPA and can contain scents. It is not as effective as the purer IPA. Check the label on the bottle to verify the amount of IPA and "other" ingredients before using rubbing alcohol.
Cheers
完成的
Hi @jayeff
Sorry, I meant the same thing as you mention, just did not remember the English name...
完成的
添加一条评论
添加你的答案
clari 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 37
总计 2,075
