跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
210 个问题 查看全部
LCD Horizontal white and black lines
Replaced battery, worked for 2-3 days then battery stopped taking charge.
Opened up again to disconnect and reconnect battery - iPad appear to now boot up again but LCD is only showing lines (see images).
Tried to fiddle with flatwire and connector to see if these is a glitch - not even a flicker on LCD to indicate anything.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
I would suspect that the LCD is damaged. It could be just a small tear in the flex, damage to the connector or a logic board issue.
If you have access to a known-good Air 2 screen assembly, then you could use that to eliminate an important variable. Unfortunately, the Air 2 screens are in short supply and very expensive.
Start by inspecting the flex and connectors under magnification, then move onto the logic board, specifically the area around the LCD connector to see if there are any dislodged components.
这个答案有帮助吗?
得分 2
1条评论:
Thanks Minho - will do
完成的
添加一条评论
Hi..Did u figure out why it was so because I am in the same situation
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lars McKie 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 91
总计 3,089
