跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
3376 个问题 查看全部
Replacing rear case, can't remove hole surrounds from old
Hi, I'm replacing the rear case of an iPhone 5 as well as swapping out the camera and volume/power button cable. I've just put the lightning connector and speaker into the new housing and notice the old case had a plastic part with surrounds/edges to both headphone jack and lightning connector holes, to make a snug fit.
Is it possible to remove those from the old case (with a heat gun?) or to replace them with new? a quick look on eBay didn't turn up anything.
all the best and thanks,
Tom
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
You can remove all you need with heat and a blade like tool. No need for a heat gun which would be too powerful and probably damage the tiny plastic parts, go with a hair dryer or put it for some time on something warm enough to soften the adhesive. Don't forget the small metal gaskets you find under the lightning connector where the central screws are fitted.
这个答案有帮助吗?
得分 3
评论:
Thanks so much, @arbaman I'm having trouble remembering which holes the 4 washers were for under there. they moved around quite a bit when I took the part out. is it the central most 4 holes, 2 above two below?
完成的
Ah they're raised, those 4 holes. got it now.
完成的
Great, you found them, the 4 central ones !
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 15
