跳转到主内容
Arport Etreme card not detected?
I have installed airport extreme card into my iMac and it does not recognize it. (I think that the Airport Extreme card has bluetooth)I need the bluetooth,to be able to use a Magic Mouse and Wireless Keyboard. I guess I could use a dongle but I don't think that will wake up the machine, and since I installed the card would like it to use the WiFi as well. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
See if the card is seen in your System Profiler. If so then run software update and see if it downloads airport software.
这个答案有帮助吗?
得分 2
9条评论:
I checked System Profiler, I am not sure what to look for but I don't see anything about an Airport Extreme or WiFi or bluetooth.
完成的
go to about this mac > more info > Network > Airport and see if it sees anything
完成的
OK I found the Airport Extreme card listed with related numbers and info but it says it is turned off, how do I turn it on?
完成的
I just checked for updates and nothing helped, I updated Itunes, and a couple others but nothing helped the airport. Thanks for any help, I appreciate it.
完成的
Go to your hard drive > Applications > Utilities > AirPort Utility and run it.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,107
