跳转到主内容
it's stuck on the white screen. with the file logo on
I got a MacBook pro from a friend. because he gave up on it. after he tried to install Linux on it. and now it's stuck on the white screen with the file logo. what could it be I have tried with many things. but if you guys culdt maybe com with some idea's. could maybe help me alot.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
最有帮助的答案
You'll likely need to replace both the HD SATA cable and the HD its self. For now lets try the cable first.
Here's the IFIXIT guide you'll need to follow: MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement and here's the needed part: MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cable. You'll also want to place some electrical tape down on the uppercase where the cable rides against as the rough surface of the aluminum of the case can wear the cable.
Since the drive does not have Mac OS-X on it you'll need to install it. I would recommend you find a friend with a Mac to help you create an OS installer thumb drive following this guide: How to make a bootable OS X 10.11 El Capitan installer drive as your system can't run anything newer than El Capitan OS-X 10.11.x. Hopefully he has the installer on his system or had at one point installed it. He may need to go to the Apps store and review what he's downloaded to download it again if he doesn't have it on his system. The one issue you may face is a certificate error which is cause by the systems clock date being outside of the certificate window Apple uses to force you to install a newer OS. Here we can still do it by going into the Preferences altering the clock to use the local time not server time and then set the date back 2015 or 2016.
Let us know how it goes!
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cable图片
产品
$34.99
这个答案有帮助吗?
得分 2
添加一条评论
is this the file logo you refer to?
Best
这个答案有帮助吗?
得分 1
评论:
yeah it is...
完成的
This is usually due to either a bad HDD cable, or the harddrive itself. Only way is to replace the two components one at a time. Best
完成的
okey I will try that and see what happens. and I will write back.
完成的
If you are in DK, you are welcome to write me. I dont know if exchanging information here is legal, so for now I'll let it be.
完成的
I'm danish ;)
完成的
显示更多的7条评论
添加一条评论
添加你的答案
Thomas Nielsen 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 109
