跳转到主内容
修复你的物品
维修的权力
商店
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
1986 个问题 查看全部
iPhone Stuck in White Apple Logo.
My iPhone Stuck in White Apple logo. I tried resetting the iPhone , Also Tried restoring the iPhone Multiple times even in DFU mode also. Restoration was successfully completed but device is again showing the same issue. Iphone is stuck in Apple logo itself. in iTunes device is detecting . Device is not under Apple Coverage and i believe if i visits Apple Support then they will advise for a whole unit replacement only. Kindly advise is there any solution for repairing this issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个回答
It seems like a bootloop.
Your iphone have problem with the new update, you can download a diffrent version of ios and downgrade it. The new update maby have a problem, and apple will fix it in time, until then you can try do plug your iphone to ituns, go to recovery and download a older version of ios. Like if you have ios 11.3 you see if you can download ios 11.1 or 11.2 and see if your problem is solved.
这个答案有帮助吗?
得分 1
评论:
Will it be possible to downgrade. My IOS version is 11.2.5. Kindly advise whether i can downgrade the same?
完成的
Here you have a link to ios 11.1
Hope it work out for you!
完成的
It is not allowing to installed since the IOS is not signed by Apple. Downgrading is not happening.
完成的
添加一条评论
You can easily try this: How to Fix iPhone Can’t Turn On & Stuck On White Apple Logo When Rebooting?
这个答案有帮助吗?
得分 0
评论:
Of course this site is verified, it is free and reliable. But you may not save your date. did you backup your device on iTunes before?
完成的
添加一条评论
添加你的答案
HASHIR ABOOBACKER 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,410
