跳转到主内容
Sony Cyber-shot DSC-W5 5.1 Megapixel
10 个问题 查看全部
everything is working fine but there is no backlight
i found a guide online wich fuse to change about backlight but when i opened my camera it was different motherboard (it did not have that fuse)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The only other way would be to make sure that you have the right manual and it would be helpful if you have the information on your logic board.
Anyhow I posted a service manual with corrections on my file server for you to download and check if it helps. Again, if you can provide more info on your logic board, that would be great.
Level 1
Level 2
Level 3
Level 2 Supplement 2
Level 2 Supplement 4
Let me know if you have any furhter question, and good luck to you.
这个答案有帮助吗?
得分 2
5条评论:
>EP GW< IBI,HF
1-865-826-11 SY-001
is this it?
完成的
Harbin Ametaj can you clarify this a bit? Is this.....???
完成的
these are the letters on the motherboard. are these the version number?
完成的
i checked the backlight "LEDs" they work but independetly when i try to power all 3 from the flex cable they don`t work !? today i`ll check does the camera provide power to the leds/SMD lights (sorry i don`t know what they are called)
完成的
Harbin, I think you are on the right way. Your LCD lights up but not when connected to the logic board by the cable. Make sure your cable is okay, without breaks and also your connector without corrosion. I am certain there is a fuse on your logic board. Check that one as well. I believe the number you gave me could be your logic board number. See in the manual if it matches. If your logic board does not supply the power, it is the fuse.
完成的
添加一条评论
添加你的答案
Harbin Ametaj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,226
