Our power went out at home and wave radio will not power up at all?
Wave radio will not power up. Is this an issue that can be resolved?
Sounds like a power surge my have blown the fuse in it.
open up unit
Look for fuse (should be aroung where the power comes in)
Remove fuse and get a replacement
Reinstall and re assemble unit
这个答案有帮助吗?
And, make sure plug has been REMOVED from the wall before doing this. :)
Hi Bo, Before checking the fuse, what type outlet is it plugged into. If it’s a GFI type outlet, see if it may have tripped. You can reset it on the outlet. If it’s a regular outlet, plug something else into it like a small lamp. If no power then check the breaker to see if it tripped, if not then check the fuse as Overdrv said above. I hope you get it back up and running. Please let us know.... Thanks, John
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 1,301
