Can't make or take calls text and data are good
iPhone 5 won't take a call or make one their is a code a person. Put one on and it worked great then bam I need code and I tried *#31# didn't work need help
Seems like an activation issue. This issue occurs a lot on android when rooting a device as well. You will need to backup your data to iTunes then use iTunes to factory reset the phone and completely wipe it so you will have to reactivate it. If iTunes reset doesn't work, then you will have to bring the phone into your carriers nearest store for them to manually activate the device in-store.
If this helped, let me know!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 56
I'm sorry, I have no idea what you're trying to say except for your iPhone 5 won't make or receive any calls. I don't know what anything from "their is a code a person" to the end of your 'sentence' means. Is the "code" you're talking about a PIN code to unlock the phone? Did you enter a PIN code and now have forgotten it? And what do you mean by "person"?
#31# is just a way to block caller ID to the next call you make.
由 Steve 完成的
I try to call a contract and It goes straight to their voicemail but when I tried texting it doesn’t go through
由 Laura gibson 完成的
