跳转到主内容
Laptop will not charge in cart, but will charge with external adapter.
We have a Dell cart that holds 30 Dell Latitude 3340's. Specific laptops have started to not charge while docked in cart. They will charge with external AC adapters. The path is the following: Power goes to cart, AC adapters are plugged into outlet behind laptop, AC adapter plugs into a female-to-male adapter that is mounted to a try, laptop slides into tray to charge. I have tried changing the battery, changing AC adapter, changing tray. Nothing seems to get the laptop to charge via the dock. Other laptops charge in the same tray.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
After further troubleshooting, I have found the issue. Removed bottom cover of laptop to expose DC jack. Found the jack was slightly shifted inward. This caused the slot adapter to not make a full connection. Pushed jack outward and secured bottom plate. Laptop now charges in tray.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aaron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 129
