Some pieces are missing! causing some ghost touches
Hello,
So I've bought an Iphone 6 plus (Used For cheap Price), 3 days later I found that I have some Touch issues, Occasional ghost touches at the right side of the screen.
I decided to check the display connectors, so I took off my Display and i found that
1- The front panel cable bracket is missing, the panel showing in the Pohot.
2- The battery is too small for it's housing, like When I shake the phone, the battery keeps moving inside the phone,I can hear and feel it.
I guess causing these ghost touches is the battery, more like electrostatic signals, because the panel is missing ?
Can I get the missing Panel from a shop ?
and what about the Battery?
4条评论
the battery might not be stuck down, you could use adhesive strips or double sided tape
由 daniel 完成的
So, It's normal to be smaller than it's housing?
I guess I can use some adhesive strips.
由 Omer 完成的
have you got a photo of the way the battery is
由 daniel 完成的
if that is it in the photo the size looks fine
由 daniel 完成的
