跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
What does this cable connect to?
Here is an additional photo, maybe this will help.
Apparently I cut the cable to the left of the tear camera while taking off the display. I can't determine what it connects to. Can you tell me what it goes to and can I buy a part to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi,
This may be of some help in getting answers. 在已经存在的问题里加入图片 Apologies if you already know this.
Is it visible in the ifixit iPad Mini 2 Wi-Fi Rear Facing Camera Replacement guide?
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
iPad Mini 2 Wi-Fi Rear Facing Camera图片
指南
难度:
困难
这个答案有帮助吗?
得分 2
3条评论:
Jayeff, thanks for sharing how to add photos. I have added a photo to my question. If you can help me I would be grateful
完成的
Hi,
Perhaps @refectio might know.
完成的
Jayeff, I added a couple of photos, can you help me determine what I cut, and how to fix it? Or @refectio
完成的
添加一条评论
This is a cellular model, likely cellular/GPS antenna or capacitive prox censor. The picture is not clear enough to tell for sure.
这个答案有帮助吗?
得分 0
2条评论:
Tom, I added a photo does that help you explain it?
完成的
Looks like prox sensor cable, not important. You can fix this by replacing the top right antenna assembly.
完成的
添加一条评论
I agree with Tom Chai, I believe this is for the Cellular module.
I did a lot of planning before I got my own iPad, and a cellular feature was one option I didn't want to pay for.
Considering some of the parts I have seen in some laptops and phones, this looks like it could be a cellular module
这个答案有帮助吗?
得分 0
3条评论:
How can I fix the cut cable?
完成的
I can't tell what kind of cable it is. basically if you know how many wires you can just swap them out. they look pretty small, so you may want to go 28 awg or at least 24 awg (smaller is actually bigger) but it also depends where the wires connect to (are you missing the cellular module?) These may even be antennas for the wifi module, which are suppose to be cut and connect to nothing.
完成的
Common things to check for is to see if the it works (power button cable?) turn it on and off if you can. see if the camera and wifi work. if you could do an investigative video, showing of the wire, and then slowly moving the camera over the area so that we could look for any common connection points, we may be able to spot something that looks odd. Mainly looking for another wire or broken solder joint. You should be able to fix this with a knife to strip the wire some more, and a soldering iron if you have one.
完成的
添加一条评论
添加你的答案
latraelmayo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 91
