跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2189 个问题 查看全部
After replacing the power cable screen flickers, but only during calls
I followed the guide to replace the power/sensor cable and everything apart for one minor detail seems to be fine now.
In the process the only other thing I did was to replace the battery.
The outcome is a fully functional iPhone 4S (tested cameras, WiFi, mobile telephony as well as internet). But whenever a call is received or placed, the screen which shows, among other things, the button to hang up, to enable loudspeakers etc, flickers.
The flickering only happens during calls (no matter whether incoming or outgoing).
What gives? Can anyone point out a specific reason why this would happen (and of course a remedy)?
For now I am considering this more of a cosmetic issue. During a call it rarely matters if the screen flickers (except when using the dial pad to enter further digits during a hotline call).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The proximity sensor is on the power button ribbon cable assembly. Either that is not mounted properly or is faulty.
I have marked it in red here:
这个答案有帮助吗?
得分 3
3条评论:
And that sensor, if defective, could cause the symptoms?
完成的
Usually they don't work at all when faulty.
It's either blocked by something or not mounted properly
完成的
Thank you! I'll see if I can make out any blockage and perhaps order a replacement if I can't.
完成的
添加一条评论
添加你的答案
Access Denied 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 41
