跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2688 个问题 查看全部
iPhone 6s Won’t Charge Or Connect To iTunes
Hi, device is an iPhone 6s, came in with no power and wasn’t drawing any power from charger.
First thoughts were charging port as Lightning Cable felt a wee bit loose when connected
I placed a new battery on top of the old one just to attempt to power on device and it booted on just fine.
I tried charging once powered on but still nothing. Therefore I went ahead and changed the charging port but still the device won’t charge or be picked up by computer.
Am I right in ruling out charge ic as Would a charge ic issue still let you connect to computer?
Have tried 2 ports in case one had a Fault.
No sign of any charging port connector damage under scope.
Any tips appreciated thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Tristar chip needs replaced, microsoldering job.
Symptoms of bad tristar:
- iPhone not being detected by computer
- Not charging while on
- Not charging when battery is flat
- Apple logo not displaying when battery is unplugged and charger is plugged in.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Niall 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 770
