跳转到主内容
A clothing iron, also called a flatiron, is a heated surface used to remove wrinkles from fabric.
79 个问题 查看全部
How to disassemble B&D travel iron with model TI250?
How to disassemble B&D travel iron with model TI250 ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I've done a bit of a search for you, and all I can say at this point until someone more knowledgeable chimes in is. You will have to start from the top down. You will need to try and find the screws that hold it all together, and this will be trial and error for you. Look for plugs or stickers that may conceal screw holes, or tabs that can with gentle prying be unclipped.
这个答案有帮助吗?
得分 1
1条评论:
Thanks, I will keep trying tell i find something. It has only two visible screws at the back side.
完成的
添加一条评论
添加你的答案
Mohamed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 63
