跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
iPad Air 1 issues charging after replacing charging port
Hi,
After replacing the charging port on my iPad Air 1st gen, this is the first time I run into this kind issue. When plugging in the iPad, it boots up, and shows the charging symbole and actually charges... BUT... if I disconnect the USB cable and reconnect it back, then it doesn't charge. The only way I can get it to charge is if I shutdown the iPad, leave the cable plugged in, it will reboot on its own, and show the charging symbol again and will be charging.
So, my questions is, why does it stop charging if I disconnect it? Why does it only work when booting up with cable connected?
I've even removed the motherboard and made sure my solder joints were all good. Same results...
Is this a bad soldering job? bad charging port? or something on the motherboard?
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I'm guessing tristar but try another charging port as it can cause this too.
I had a shorted charging port on an iPhone 5 where it would charge for 30 seconds then stop. Tristar chip was faulty as it probably went both bad at the same time.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jason Savoie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,439
