跳转到主内容
加入维修社区 - 创建账户
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
Broken screen can't deactivate
I recently cracked the edge of my screen causing a few problems so I turned off screen lock and seems ok 90% of the time. Today's problem is I put battery saver on as was out and only had 5% and now I can't disable it as the screen times out straight away. To be able to get the phone screen back to working order I need to disable the saver back to normal. Help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
It fixed my problem as weel. I was unable to turn off the device and boot into recovery mode. Thanks for the post
完成的
Hi my s7 edge has a broken screen cant see anything, and i accidentally turned on battery optimization pl3ase helo!?!?
完成的
添加一条评论
4个答案
已选择的解决方案
Try this:-
You can force Galaxy S7 or S7 edge to power off without unlocking the phone by following these steps:
Step 1: Connect Galaxy S7 and S7 edge to wall charger with the USB cable and make sure it is charging.
Step 2: Press and hold Volume down button and Power button (holding two buttons) for about 7 seconds.
Step 3: Release power button, then volume down button.
Now, Galaxy S7 or S7 edge should be powered off. You can wake up the screen to verify. It should show a charging battery icon.
这个答案有帮助吗?
得分 22
11条评论:
I have spent hours trying to find a solution. This is the only one that works. Thank you very, very much. Now I can boot into TWRP and get all my files out.
完成的
yes this is hard to find knowledge! On my broken note 5, this solution works too (just pressing down + power button only reboots phone, not power off). Samsung should have made it easier to force power off phone with sealed in battery
完成的
100% working for my broken screen,Thanks
完成的
This doesn't work for me. It's just causing the hard reset but the phone immediately powers back up. I need the phone to stay off so I can take out my sim card
完成的
when i try this it just restarts my phone? HELP PLEASE.
完成的
显示更多的6条评论
添加一条评论
My Galaxy 7 started repeatedly rebooting and the hard shut off did not work. I have a replacement phone but have files I need to get off the G7. Is there another way to cancel the automatic rebooting process that the phone is stuck in?
这个答案有帮助吗?
得分 1
添加一条评论
It's really too bad that no one has a universal fix for this. What i ended up doing was taking the phone apart and removing the battery. What could be the problem is the button mechanisms are faulty from the damage as well.
这个答案有帮助吗?
得分 0
添加一条评论
Thank you very much ... It did work
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 33
总计 67,110
