跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
Replacing Motherboard With Newer Model
Okay so I have a late 08 MacBook. The shell says MacBook Pro at the bottom of the screen, but the About This Mac section just says MacBook. It makes mew think that I'm running a Macbook motherboard in a Pro Shell. (if that's even possible, idk I have very limited knowledge on this stuff)
My Question is, can I replace the motherboard in this shell to technically run a newer model of MacBook so that I can get the High Sierra Software, instead of being limited to El Capitan? It'd be much easier and cost efficient to do this instead of buying a whole new computer, so thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Unfortunately, no. You cannot use a Logic Board from another Mac in this computer due to the design. Logic Boards are made to fit the curves of the computer it is designed for, therefore preventing you from using foreign logic Boards on it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hayden Kelly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 112
