跳转到主内容
Repair guides for machines designed to move slowly and get big jobs done, including farm vehicles and construction vehicles designed for specialty tasks.
83 个问题 查看全部
How do I replace a fuel pump on a Ford 3000 tractor?
My fuel pump is leaking and I need to repair or replace it. How do I do this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
@ddavis317 any idea what year your tractor is? A serial number will help with that. Also what engine does it have? The 3000 came with either a Ford 2.6L 3-cyl gasoline or a Ford Ford 2.9L 3-cyl diesel
完成的
Hi Turkey, I am pretty sure its a 1975, it is a 3 cyl. gas. Thanks for reply
完成的
添加一条评论
2个答案
最有帮助的答案
@ddavis317 straight forward for the gasoline engine
Here is the Fuel System part of the SM Ford-tractor-Fuel-System.pdf for the 1965-1975 Ford Tractor
这个答案有帮助吗?
得分 1
添加一条评论
Replacing the Fuel Pump on a Ford 3000 Tractor:
Materials Needed:
  1. New fuel pump
  2. Wrenches and socket set
  3. Gasket sealant
  4. Container for fuel drainage
  5. Rags or towels
  6. Safety glasses
Procedure:
  1. Drain the Fuel:
  2. Remove the Fuel Lines:
  3. Remove the Old Fuel Pump:
  4. Clean the Mounting Surface:
  5. Install the New Fuel Pump:
  6. Reconnect Fuel Lines:
  7. Prime the Fuel System:
  8. Check for Leaks:
  9. Reconnect the Battery:
  10. Test the Tractor:
这个答案有帮助吗?
得分 0
1条评论:
@jerryrodan AI generated answers need to be flagged/marked as such. You are responsible for the content of the AI regurgitated technobabble answer.
完成的
添加一条评论
添加你的答案
Marty 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 13
总计 5,144
