跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Is there any way to see if the homebutton is original?
Hey, is there any way to see if the homebutton is original?
Got one that dosent work but i dont know if they replaced it before so it dosent work because of that.
I also got one that I do know is original.
Components looks the same, the qr code dosent.
and numbers on the flex is:
821-00912-02
MFC3116
dont know if that one is original.
The one I know is original says:
821-009
MK12-02.
Thanks for any ansers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
To be blunt does not matter if it's original or not.
The only home button that will ever work on an iPhone 7 and higher is the same home button that came with the phone.
这个答案有帮助吗?
得分 0
1条评论:
That I do know, and i do not think they took an other iPhone 7 original homebutton so they screwed two phones.
Bought it water damaged and dead, and have fixed that and there is not any other damage on the board, and they have made a little damage on the homebutton flex, the little one after the "u10" ic, but the homebutton dosent work at all so thinks it's an copy. Want to be sure doh
完成的
添加一条评论
添加你的答案
Jonny 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 780
