跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 个问题 查看全部
iMac turned into external monitor, backlight issue
Hello everyone,
Sorry for my bad english, I hope everything is clear.
Few days ago I turned my old iMac (late 2009) into an external monitor.
Monitor: LG LM270WQ1-SDE3
Controller Board: HDMI-VGA-DVI-Controller-Driver-Board-Kit-for-2560-1440-2K-LCD-LM270WQ1-SDE3 (can't post ebay link)
Everything work perfectly but what bother me its this backlight shadow
I found a lot of guides and tips to fix this issue but I don't know which one fit for me.
I already try to unplug, clear from dust and plug the wire on the top bottom behind the monitor but nothing.
How can I figure out what is my monitor issue?
Thanks
Update 1: (28/01/2018)
Here there are some pictures of what I've done so far.
Update 2: (30/01/18)
I was not sure about what to check with multimeter (its an old 1, not digital) so i've measured the voltage at this pin (controller board side)
in pairs of two to two, and all of them deliver 12V.
I did the same here
and again 12V per pair (I measured only the right side for now, the 1 with the blacklight issue, I was running out of time)
I also took some other pictures
if you can, try to explain me exactly where I've to put the hands on, I'm not an electronic expert
Update 3: (07/02/2018)
Here I'm again thanks to @oldturkey03 to push me further to check the led array.
Thats what i find out, was hard to take a picture due the really high light, but what we can see (not really) it's the huge difference between left and right (the monitor its upside down) and there's also 1 burned led in the middle of the bar, right side of the image (left side of the monitor).
What I've noticed is that in the right side of the image the LED array have 2 different intensity of light. It start with a very bright light then continue with 2 less bright ones
Like this:
The right side instead seems like having only the less bright one
Update 3.1: (07/02/2018)
Well this time I had to use the measurement tool without help, I placed the two "spikes"
on the board two by two in both red and green circle as shown in the image.
And this is what it return in ALL my try, in both banks
If I didn't mess up with the measurement tool setup this is what we got
Update 4: (17/02/2018)
Seems like the only one in the whole web selling this item its in China from ebay and it sell a reconditioned item, I'm waiting Feb 24th to contact the seller, since he is on some kind of China holyday.
This is the name of the item on ebay:
LED strip For Apple 27‘’ laptop LM270WQ1-SDC2 M270WQ1-SDA2 SDB1 SDE3 SDE5 SDF1
and the seller name is kcelectron
What bother me is that I've to add money for an used reconditioned item that its not guarantee will work for long time. Also its not specific for my monitor instead it "fit" with a big variety of them (SDA2 SDB1 SDE3 SDE5 SDF1). Any thought?
Looking forward for reply
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
Your english is great and this question is very detailed and good. Great job!
完成的
thanks @captainsnowball
完成的
@xfiloo yes, go ahead and do test the voltage. When you do have your meter, test both banks and let us know what voltage you are getting on the left and right bank.
完成的
@oldturkey03 new update
完成的
@xfiloo okay that looks good if it is the same on all banks. In that case you do have trouble with the actual LED strip (array). I'll see if I can find one somewhere.
完成的
添加一条评论
1个答案
最有帮助的答案
@xfiloo what you are not getting is a backlight on the left side (right looking at it) of the monitor. You need to check your driver to see if it does deliver the same voltages as it does to the other side. If you can post some images of the connectors on your panel as well as your driver I am sure we can figure it out. If it does then your monitor has issues with the LED array. You would have to take the panel apart (absolutely doable) and check/replace the array.
Update (01/28/2018)
Use your multimeter and measure the Left bar compared to the Right bar and see if this is the same. If it is the issue is your backlight, if it is not then the issue is your driver.
这个答案有帮助吗?
得分 4
12条评论:
Thanks for the reply @oldturkey03 , I have updated the post
完成的
I have updated my post
完成的
help me please @oldturkey03
完成的
Since you seem to have the right voltage coming from your LED driver the issue will most likely be the backlight inside the panel. You can take the panel apart ( there are diffuser sheets that look like they are made out of plastic, keep those in the same order as you remove them) then check the backlight array
完成的
Sorry for late answer, I had lots of stuff to do these days. I did find a guide about opening the monitor and check the led. But what if the led are burnt? I searched a bit and seems hard to find a replacement
完成的
显示更多的7条评论
添加一条评论
添加你的答案
Filippo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 44
总计 3,694
