跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
Replacing screen with other phone's screen
So I've got 2 sgs3's, one of which is bricked beyond everything.
The other one's got about 10 million cracks in its screen.
Will it be possible (using the iFixit electronics essential toolkit) to take one screen and replace it with the other?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes it is possible. If they are both for the same carrier you can transfer the screen and midframe to the other phone. If they are from different carriers like at&t(gsm) and Verizon (cdma) then the midframe and motherboard layout are slightly different. In this case you can still transfer the display but without the midframe. If you had to you can also use a Dremel tool to grind down the midframe to make another carriers motherboard fit the midframe. This is not the funnest thing to do but is doable if needed. All carriers use the same display but depending on the cellular technology used (gsm vs cdma) the midframe and motherboard vary slightly. Removing just the display from the midframe, may or may not be necessary depending on the carrier. Either way the display is the same for all carriers so yes you can swap them out if you wish.
这个答案有帮助吗?
得分 1
1条评论:
Sweet, they are from the same carrier by the way so I should be fine.
完成的
添加一条评论
添加你的答案
Elian Pangalila 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 24
总计 164
