跳转到主内容
The Xbox One X (Model 1787) is Microsoft's latest high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
136 个问题 查看全部
Will an Xbox One X fit a CPU waterblock?
I want to fit a CPU waterblock for a PC onto the xbox one x motherboard to cool the processor. I need to know how far apart the holes are that I've marked in the attached picture to see if a waterblock is compatible.
https://imgur.com/a/UTW8U
Also, will passive heatsinks be adequate for the memory modules around the processor?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
You will need a block that covers the same area that the original vapor chamber does unless you find a new radical way to cool the other chips. Mini heatsink on each chip will not be enough. Kid next door did it and killed his system.
这个答案有帮助吗?
得分 0
添加一条评论
What if oyou got a big pice of copper that get alle the chips like the original and then got a big waterblock on that? .. maby ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Myles 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 8
总计 1,701
