跳转到主内容
The following information is intended to help service the Nerf N-Strike Elite Strongarm . The Strongarm was released in 2013 by Hasbro under their Nerf brand.
18 个问题 查看全部
Why won’t my barrel turn after I shoot
I had my strong arm for a while and I can’t figure out why when I shoot it the barrel won’t turn and also it creates a loud sound when I shoot it. Very rarely would the barrel turn when I shoot, what should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
It could be that the gears are slipping or worn out
这个答案有帮助吗?
得分 0
2条评论:
Should I open it check for a problem?
完成的
Ter ar please u can send it to that can fix it but unles u hav the rite gier u won’t be abol to fix it
完成的
添加一条评论
Mine was doing this, and it turns out that the gears were fine, but a screw post that holds the gear assembly together had split such that the assembly was slipping.
Attempting a repair with epoxy, but expect to have to find parts somewhere, or build a new mechanism.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christine Berry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 742
