跳转到主内容
修复你的物品
维修的权力
配件 & 工具
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4982 个问题 查看全部
I don't know if my phone works
So I just got an iPhone 6 from a friend. It has a broken screen, and from the looks of it, it may have a broken display as well. I have plugged it in to multiple chargers to see if it would show any signs of life. No vibration when I plugged it in, none when I held the power button, and none other than that. I plugged it multiple computers with multiple cords, and they did not recognize that something was plugged in at all. I don't know how to find out if it works so I know if it's worth trying to fix or not.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
I think not worth.
完成的
It's the easiest for me to get, and I've found replacement screens for $25 so I just need to know if that's the only repair necessary, if it'll take much more than I'll pass on it, but if that's it then I'll do it
完成的
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
3个回答
已选择的解决方案
If you got a dead battery it won't connect to iTunes or show any sign of life sometimes.
If you have tools to open the phone up, open it and remove the plate for the battery contact and unplug det battery from the motherboard. Then plug in the charger and see if it goes to the Apple logo. If so, the battery is bad and would need an replacement to.
Here's how:
如何更换iPhone 6电池
A tips is to check with imei number first so it dosent have find my iPhone activated (if your friend can't fix so it gets signed out)
这个答案有帮助吗?
得分 0
评论:
Thank you so much, I'll have to try that, I'm not sure when I'll be able to but hopefully soon
完成的
And if apple logo does not appear with battery unplugged and charger plugged in then it's either a bad Tristar charging chip or micro soldering work needs to be done on it (if a known good charged battery has been tried on there).
完成的
添加一条评论
最有帮助的答案
Battery could just be flat. Leave it plugged in charger for at least half an hour then plug into computer and open up iTunes to see if it detects it.
这个答案有帮助吗?
得分 2
评论:
Thanks for that suggestion, I've had it plugged in all day, and I just plugged it into the computer, but no response from itunes
完成的
添加一条评论
Hello,
Just a screen replacement won't do it. But save the phone maybe you find like a 10€ screen in the future and replace it then.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Devin Williams 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 46
