跳转到主内容
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
100 个问题 查看全部
PSP 1000 will not charge or power on with charger
Hi folks
i done a quick google search & couldn't find any real info on this.
i have a psp 1000 & it will not charge the battery or power on with the charger plugged in. it works with a charged battery & the charger works fine on my second psp 1000.
i have installed the USB MOD to see if it will charge by USB but unfortunately nothing :(
i have also changed the yellow power port on the bottom & still nothing.
seeing as the psp has been out for 13 years now i was hoping someone may have a fix for this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@therealoctavus Hi!
Just a quick question: does it charge if you install a known-good battery? Does the other (known-good) PSP work with the battery from the PSP you're having problems with? If so, consider replacing the battery.
这个答案有帮助吗?
得分 1
4条评论:
when i have the charger connected without the battery the psp dose not power on so its not the battery its something to do with the psp itself. the psp came without a battery & i have tried two different batteries
完成的
@therealoctavus Have you checked the fuse? Have a look at this post, maybe it helps How to repair my psp when can't on power
完成的
thanks for the reply & link Alex, ill give it a look & see if this sorts my problem. :)
完成的
Did the fuse fix the issue?
完成的
添加一条评论
添加你的答案
TheRealOctavus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 38
总计 6,703
