My 96 ford probe gt is shutting off and turning back on.
I had just replaced the timing belt and the water pump with pulleys, and put a new distributor in. The wire that goes to my security system was cut. Not sure if that would effect anything. I'm not sure if it's the crank shaft sensor either.
7条评论
@renobeno26 "is shutting off and turning back on." all by itself? Does that all the time or only when driving?
由 oldturkey03 完成的
Yes, after driving for 15-20 minutes it shuts off then turns on. It does it twice within 1-2 minutes. Only when I'm driving.
由 Reno Brogie 完成的
If it were part of your security system, it prob wouldn't start at all. Two things, try and scan it for a code. 2nd is, does it work perfectly fine when cold, then when it heats up it gives problems? If so that is a bad crank angle sensor as a general rule. But if it were the CaS that was cut it run OK then over rev, stutter and almost shutoff then start up again.
由 sm_vulkus 完成的
No codes pop up, check engine light does come on when it acts up the leaves as soon as it stops. I drove it when the engine was cold, drove fine after driving about 20 block or so. I came back out about 30 minutes later and about a minute of driving it was acting up. It died completely after going a few blocks. I started it back up and put it in drive died right away. So I started it up left it to run in Park and died. From there I had it towed back to my complex. That's all I have have done.
由 Reno Brogie 完成的
this is a 96 so if it caste a light then there should be a pending code . are you using an OBDII ? Is it possible the wire that were cut are shorting against anything? did you wire the cut wires back together . If so did you solder or butt joint press them
由 Jimfixer 完成的
显示更多的2条评论
