跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Battery swapped but home button and touchID not working
Got that $29 battery kit, was excited to do the swap. Followed instructions step by step. Got it to power up and then... the home/touchID button doesn't work. I was careful not touch the home button or the surrounding area. Took it apart again and made sure all of the ribbons have connected correctly yet, nada :/. Someone explain to me what could be wrong? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Only explanation I can think of is the home button extension cable coming from the screen is either damaged or the connector on the logic board for the home button is damaged.
这个答案有帮助吗?
得分 1
1条评论:
i resorted to activating assistive touch... well at least I have a brand new battery :/
完成的
添加一条评论
I would look for a tear in any of the cables. Specifically the Home Button to Logic Board cable that is with the LCD/Digitizer connector, and the front facing camera connector.
I also surely hope you've tried the good and faithful hard reset.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Binh Tran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 58
